Unable to log in to routers remotely
Jan 10th, 2008
I am able to log in to my routers from LAN-
However when i vpn, I am unable to get even a response from a branch router. I can log into other routers at different sites. For some reason though, I get no response from the 4 IP addresses configured on the
interfaces for this particular router
I am able to log into a switch that is direclty connected to it-
And i attempt to telnet through that switch, but i get a "password,required but not set" response. I do have username/pw and login local configured on the vty lines.
does this make sense?
nygenxny123 Fri, 01/11/2008 - 03:52
i have configured
username xxxx privilege 1 password xxxx
enable password xxxx
line vty 0 4
login local
any ideas?
