Ace HTTP Probe expect regex
csco10387876
I have a question about the config of the ACe probe.
I have the following probe defined :
probe http P_HTTP_TEST
interval 5
passdetect interval 2
passdetect count 2
request method get url /test
expect status 200 200
expect regex trululu
I would like to use the regex just like the expect string on the csm probe...
The regex doesn't seem to work as the strin trululu is not on the page tested.
I guess the expect status override the regex but without the expect status it doesn't work either.
Anyone know how exactly the probe expect works for http ?
Another question, on the CSM module, the tcp probe by default use the real port for the probe, not the default port of the probe type, is it possible to change that so it mimmicks the CSM way of working ?
Thanks a lot ;-)
7 Replies 7
Gilles Dufour
your config works for me
http method : GET
http url : /small.html
conn termination : GRACEFUL
expect offset : 0 , open timeout : 10
expect regex : trululu
send data : -
--------------------- probe results --------------------
probe association probed-address probes failed passed health
serverfarm : linux1-80
real : linux1[80]
192.168.30.27 2 2 0 FAILED
Socket state : CLOSED
No. Passed states : 0 No. Failed states : 1
No. Probes skipped : 0 Last status code : 200
No. Out of Sockets : 0 No. Internal error: 0
Last disconnect err : User defined Reg-Exp was not found in Host Response
Last probe time : Fri Jan 11 08:57:55 2008
Last fail time : Fri Jan 11 08:57:50 2008
See the last disconnect error.
Get the same output as me and see the status of your probe - share with us if still not working.
We're not going to change the current behavior.
If you want the ACE module to use the port of the real server, do not specify the port in the probe configuration.
If you do specify a port, it will override the one of the real.
BTW, this is the same behavior on the CSM.
Gilles.
here is what I get :
Current config :
interval 5
passdetect count 2
sh probe P_HTTP_TEST detail
probe : P_HTTP_TEST
type : HTTP, state : ACTIVE
description :
port : 80 address : 0.0.0.0 addr type : -
interval : 5 pass intvl : 2 pass count : 2
fail count: 3 recv timeout: 10
http method : GET
http url : /test
send data : -
real : R_xxx[0]
serverfarm: SF_xxx_TEST
10.xx.0.xx 39 39 0 FAILED
No. Probes skipped : 0 Last status code : 0
Last disconnect err : Received invalid status code
Last probe time : Fri Jan 11 09:37:58 2008
Last fail time : Fri Jan 11 09:36:40 2008
Last active time : Never
for de default tcp port, on the documentation there is a list that says the default tcp port used is 80, if I have a real listening to port 8080, and I try to put the probe either on the serverfarm or the real itself, I see tcp connection on the 80 port instead of the 8080 port. Strange, maybe os bug.
my default tcp probe is :
probe tcp P_TCP_DEFAULT
description probe defaut pour tcp
interval 5
passdetect count 2
thanks for your help.
What is strange is that the http probe when I remove the expect status, the failed reason is still a invalid code and not "User defined Reg-Exp was not found in Host Response"
strange ;-) (I always have strange things with those Lb)
if you only want the regexp to be considered for success or failure, configure an 'expect status 0 999' to permit all status code.
The regexp is only applied after the status matched the expect status.
Regarding your probe, could you show the serverfarm to which you applied the probe and a 'show probe name P_TCP_DEFAULT detail'
Gilles.
here is a sample :
serverfarm : SF_INTRAMUROS_PRD_WWW
real : R_ANUBIS[8082]
10.6.103.47 2108020 2108020 0 FAILED
No. Probes skipped : 1060 Last status code : 0
Last disconnect err : Connection refused by server
Last probe time : Fri Jan 11 10:42:58 2008
Last fail time : Fri Nov 23 14:54:13 2007
do you have any idea why the expect regex doesn't work and return a invalid status code insteand of string not found ? this is quite disturbing.
as I said, you need to configure the expect status.
It is mandatory for the regexp to work.
Also, the response status must be in the range you have configured.
Try to configure an expect status 0 999
G.
Gilles,
I configured both expect status 0 999 and the expect regex trululu.
Now the probe is always successfull, as if the regex was not configured.
I will test with a simpler web service and keep you posted...
This seems to be bug related to some version of ACE software as HTTP return code overrides missing regexp. For sure this bug is present in:
system:    Version A2(2.0) [build 3.0(0)A2(2.0)]
Notice the difference between 192.168.1.1 (is missing regex in HTTP response) and 192.168.1.2 (sends regexp in HTTP response). Both are successful and as addition 192.168.1.1 (missing regexp) is showing last status code 200 which seems to be sufficient for probe to pass. 192.168.1.2 (which sends expected regexp) doesn't show last status code.
probe       : tw2_http_81
type        : HTTP
state       : ACTIVE
description :
   port      : 81      address     : 0.0.0.0         addr type  : -
   interval  : 30      pass intvl  : 30              pass count : 1
   fail count: 1       recv timeout: 10
   http method      : GET
   http url         : /knowtw2-f/livelink.exe?func=ll&objtype=142&bypass
   expect regex     : lbmonitor
   send data        : -
     real      : 192.168.1.1[81]
                       192.168.1.1    2          0          2          SUCCESS
   No. Passed states   : 1         No. Failed states : 0
   Last disconnect err :  -
   Last probe time     : Mon Nov  7 12:38:42 2011
   Last fail time      : Never
   Last active time    : Mon Nov  7 12:38:22 2011
     real      : 192.168.1.2[81]
                       192.168.1.2    2          0          2          SUCCESS
   Last probe time     : Mon Nov  7 12:38:27 2011
   Last active time    : Mon Nov  7 12:37:58 2011
