VPN drive mapping issue
Jan 11th, 2008
using a 877 router with a site to site VPN we are getting a connection issue when trying to map a drive from a server to a Pc accros the VPN tunnel we can ping and see the end PC but when we try to map a drive from server to PC we get a Semaphore time out message on the sever we are using. But the strange thing is on another server connecting to the same PC everthing works fine. Has any had this problem before as we are lost as to what is casiung it ?
Overall Rating: 0 (1 ratings)
didyap Thu, 01/17/2008 - 07:20
This is not a vpn tunnel issue. The problem of Semaphore timeout is generally because of local server OS implementation. Check if the services for network mapping are running on the server OS.
