Help needed with a Cisco 800 router
Jan 11th, 2008
can someone help me, the router is allways using the second b-channel, please see attached config . the router should only use one B-Channel everytime
jsivulka Thu, 01/17/2008 - 07:27
Actually your router is not correctly configured for multilink PPP. After the first B-channel connects, the CALLING router again dials the same number. The switch at the remote end, closest to the CALLED router recognizes that the first B-channel is busy, and transfers the call onto the second B-channel, and thereby makes bundling possible.
The following link will help you:
CSCO11291078 Thu, 01/17/2008 - 10:18
thx for your answer, can you please explain in detail what i have to change than in my config??? or is it better to config a dialer interface where i point all routes to, then. like
interface Dialer99
description Verbindung zu tttttttt
ip address
no ip directed-broadcast
encapsulation ppp
dialer remote-name zzzzzzzzzz
dialer string xxxxxxxxxxxxxxxxxx
dialer hold-queue 20
dialer load-threshold 200 either
dialer pool 9
dialer-group 9
ppp authentication chap
ppp chap hostname yyyyyyyyyyy
ppp multilink
ip nat inside source static tcp 6010 interface dialer99 6010
ip nat inside source static tcp 6000 interface Dieler99 6000
and so on, or can i leave the IP nat as it is
no ip http server
ip classless
ip route
ip route
ip route Dialer99
ip route
ip route Dialer99
Best regards Ralf
