Extending CO VLAN
Jan 11th, 2008
Hi All,
I have 5 VLANs (Inter vlan routing is done). i want to extend this all 5 vlan to 6 remote branches. which are the technologies i can use to extend this 5 VLANs to my branches
Thank you
Vijay K
Jon Marshall Fri, 01/11/2008 - 02:45
Hi Vijay
Firstly it depends on what type of WAN connectivity you already have. If you are using MPLS connectivity you can talk to your SP about running VPLS between your sites which allows you have the same vlans shared between your sites.
If your WAN connectivity is ethernet based then you can simply set the connections up as layer 2 trunks.
Another option would possibly be L2TPv3 which would allow you to extend a vlan(s) across a L3 routed network - see attached link
http://www.cisco.com/en/US/netsol/ns588/networking_solutions_white_paper09186a008017fa6e.shtml
Alternatively do you actually need to extend these vlans or do you just need to give access to the 5 vlans from your remote sites. If so you could just route between your remote sites and the HQ.
Jon
