Overlap-sending using BRI and H323/MGCP
Answered Question
Jan 11th, 2008
Hi!
I am going to implement a Cisco2821 Gateway using BRI to PSTN in Germany. I have been told that the provider support Overlap-sending which is good because I then dont have to worrie to much how to implement the dialplan in CCM.
Am I limited to MGCP or does H323 support overlap sending using BRI. I think I am looking for the Backhaul-BRI feature here but I am not sure.
Any ideas would help.
Mattias
Correct Answer by aguha about 9 years 3 months ago
If you are using MGCP, then overlap is done in callmanager instead of H.323 gateway. But you lose lots of feature and flexibility if you do so.
It supports both BRI and PRI.
Overall Rating: 4 (1 ratings)
paolo bevilacqua Fri, 01/11/2008 - 14:35
  • Hall of Fame,
    Founding Member
Sorry, overlap in sending is not supported. you will have to realy on the interdigit timeout (3 or 4 seconds).
aguha Fri, 01/11/2008 - 14:40
H.323 also works with overlap sending/receving. You need to have at least 12.4(4) IOS.
paolo bevilacqua Fri, 01/11/2008 - 14:47
  • Hall of Fame,
    Founding Member
Please provide a config example and isdn q931 trace to support this claim (overlap sending), as I would be very interested in seeing that !
aguha Fri, 01/11/2008 - 14:57
Here you go.
I'm calling myself.
paolo bevilacqua Fri, 01/11/2008 - 15:13
  • Hall of Fame,
    Founding Member
Great, is this CCM which version, and how do you configure that ?
ASAIK, this is not possible with CME.
aguha Fri, 01/11/2008 - 19:23
As long as the route pattern has "allow overlap sending" checked, it should not matter which cm version you are running, cause the overlap sending and receiving is done by H.323 gateway, callmanager has nothing to do with it except the "route pattern", you don't need to change any service parameters even.
CME is doable also.
mkulovainio Sat, 01/12/2008 - 02:01
Hi Aguha!
Is overlap-sending done by the gateway if you are using MGCP, thougt that was part of the Backhaul function terminating at the CCM.
I am still in the Design phase with this one. Looking at your replies, with IOS 12.4(4) - H.323 and Overlap-sending is supported. Is BRI supported or is it PRI only? I saw that you attached debug.txt but how do I download it?
Mattias
Correct Answer
aguha Sat, 01/12/2008 - 11:11
paolo bevilacqua Sat, 01/12/2008 - 02:53
  • Hall of Fame,
    Founding Member
Ok, thanks!
I'm not sure about CME, because it misses an equivalent of "allow overlap sending".
