ccm traces shows routing blocked.
Jan 11th, 2008
I am running cccm 4.0(2a). I have a DID no. 43215678 and a translation pattern in CCM which translates calls to this no. to a particular extension 3333.
Sometimes it works fine but sometimes it gives an engaged tone. Once we get engaged tone if the TP is updated or restarted once then things again becomes normal.
Not sure where is the issue lying.
Any help will be helpful.
Thanks in advance.
