CAR Authentication with Null password with External DB
Jan 11th, 2008
With Radclient I send a UserName sergio with a Null password, in my Oracle DB I have the same data and when checked it
User sergio's password does not match
And when I used CAR db with the option AllowNullPassword TRUE everything work fine
01/11/2008 9:43:36: P537: Using Client: localhost
01/11/2008 9:43:36: P537: Using NAS: localhost (127.0.0.1)
01/11/2008 9:43:36: P537: Request is directly from a NAS: TRUE
01/11/2008 9:43:36: P537: Authenticating and Authorizing with Service sergio
01/11/2008 9:43:36: P537: Service sergio: Sending request to remote server sergio
01/11/2008 9:43:36: P537: ODBC client (DataSource 'sergio', Connection 2): Binding values for MarkerList in SQLStatement 'sqlsergio':
01/11/2008 9:43:36: P537: ODBC client (DataSource 'sergio', Connection 2): Binding marker variable 'UserName' with value 'sergio'
01/11/2008 9:43:36: P537: ODBC client (DataSource 'sergio', Connection 2): executing SQLStatement 'sqlsergio'
01/11/2008 9:43:36: P537: Results obtained after executing SQLStatements:
01/11/2008 9:43:36: P537: Column name: 'USUARIO' Retrieved value: 'sergio'
01/11/2008 9:43:36: P537: Column name: 'CLAVE' Retrieved value: ''
01/11/2008 9:43:36: P537: Remote Server sergio (sergio-odbc:0): user sergio's password does not match
01/11/2008 9:43:36: P537: User sergio's password does not match
01/11/2008 9:43:36: P537: Trace of Access-Reject packet
01/11/2008 9:43:36: P537: identifier = 1
01/11/2008 9:43:36: P537: length = 36
01/11/2008 9:43:36: P537: respauth = 0f:39:da:e2:fb:ea:17:d8:af:39:f1:0d:9b:32:3a:5a
01/11/2008 9:43:36: P537: Reply-Message = Access Denied
01/11/2008 9:43:36: P537: Sending response to 127.0.0.1
01/11/2008 9:43:36: Log: Request from localhost (127.0.0.1): User sergio rejected by RemoteServer sergio (UserPasswordInvalid).
01/11/2008 9:43:36: P537: Packet successfully removed
ebreniz Thu, 01/17/2008 - 07:30
  • Silver, 250 points or more
AR itself is normally comparing the password it has in the authentication request with the password it retrieves from the database With AR, it is possible to create your own authentication service script that will not check passwords. This method is not easy since you will most likely have to access an external data store. And also Check all the four AR processes are running using /opt/CSCOar/bin/arstatus
