Help with Cisco PIX 515E
Jan 11th, 2008
I want my Remote Access VPN to work to our new PIX firewall Cisco PIX 515E. With AAA to a radius server.
I want the Cisco VPN client to come with a popup which in I can fill in my details coming from the radius server.
I configured the AAA server by hand a run the VPN wizard in ASDM.
After I done this I can't log in with the client.
I think it has something to do with the vpngroup commando but the wizard didn't create anything for this.
Can somebody help me checking the config and see if anything need to be modified?
pixfirewall# sh run
: Saved
PIX Version 7.2(2)
hostname pixfirewall
domain-name default.domain.invalid
enable password xxxxxxxxxxxx encrypted
names
interface Ethernet0
nameif outside
security-level 0
ip address [External IP]
interface Ethernet1
nameif inside
security-level 100
ip address 10.1.1.7 255.255.0.0
interface Ethernet2
shutdown
no nameif
no security-level
no ip address
interface Ethernet3
shutdown
no nameif
no security-level
no ip address
interface Ethernet4
shutdown
no nameif
no security-level
no ip address
interface Ethernet5
shutdown
no nameif
no security-level
no ip address
passwd xxx
ftp mode passive
dns server-group DefaultDNS
access-list inside_nat0_outbound extended permit ip any 10.248.2.0 255.255.255.0
pager lines 24
logging enable
logging asdm informational
mtu outside 1500
mtu inside 1500
ip local pool ClientPool 10.248.2.0-10.248.2.255 mask 255.255.0.0
no failover
icmp unreachable rate-limit 1 burst-size 1
asdm image flash:/asdm-522.bin
no asdm history enable
arp timeout 14400
nat (inside) 0 access-list inside_nat0_outbound
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout uauth 0:05:00 absolute
aaa-server vpn protocol radius
aaa-server vpn host [Radius server]
key [Radius secret]
group-policy [Name] internal
group-policy [Name] attributes
dns-server value 10.1.3.100 10.1.3.101
vpn-tunnel-protocol IPSec
default-domain value intranet.[Name].nl
http server enable
http 10.1.0.0 255.255.0.0 inside
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart
crypto ipsec transform-set ESP-3DES-SHA esp-3des esp-sha-hmac
crypto dynamic-map outside_dyn_map 20 set pfs
crypto dynamic-map outside_dyn_map 20 set transform-set ESP-3DES-SHA
crypto map outside_map 65535 ipsec-isakmp dynamic outside_dyn_map
crypto map outside_map interface outside
crypto isakmp enable outside
crypto isakmp policy 10
authentication crack
encryption 3des
hash sha
group 2
lifetime 86400
tunnel-group [Name] type ipsec-ra
tunnel-group [Name] general-attributes
address-pool ClientPool
authentication-server-group vpn
default-group-policy [Name]
telnet 10.0.0.0 255.0.0.0 inside
telnet timeout 5
ssh timeout 5
console timeout 0
dhcpd address 10.1.1.8-10.1.2.7 inside
dhcpd enable inside
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
parameters
message-length maximum 512
policy-map global_policy
class inspection_default
inspect ftp
inspect h323 h225
inspect h323 ras
inspect rsh
inspect rtsp
inspect esmtp
inspect sqlnet
inspect skinny
inspect sunrpc
inspect xdmcp
inspect sip
inspect netbios
inspect tftp
service-policy global_policy global
prompt hostname context
Cryptochecksum:xxx
: end
pjhenriqs Fri, 01/11/2008 - 06:07
Do you get a prompt to put in your login details or you don't even get that?
If you do get a prompt and you put in your login details, do you see anything on the log of the RADIUS server?
What are you using? PAP, CHAP, MS-CHAP?
Paulo
tbrinkma Fri, 01/11/2008 - 06:10
No I do not get a prompt to put in my login details. Suppose to use CHAP
pjhenriqs Fri, 01/11/2008 - 06:41
And what do the logs say?
They are usually your best and quickest help.
tbrinkma Fri, 01/11/2008 - 06:53
client:
Cisco Systems VPN Client Version 4.6.02.0011
Copyright (C) 1998-2004 Cisco Systems, Inc. All Rights Reserved.
Client Type(s): Windows, WinNT
Running on: 5.1.2600 Service Pack 2
69 15:52:27.853 01/11/08 Sev=Warning/2 IKE/0xE3000099
Invalid SPI size (PayloadNotify:116)
70 15:52:27.853 01/11/08 Sev=Warning/3 IKE/0xA3000058
Received malformed message or negotiation no longer active (message id: 0x00000000)
Pix
4 Jan 11 2008 14:51:59 713903 Group = DefaultRAGroup, IP = 213.126.129.250, Error: Unable to remove PeerTblEntry
3 Jan 11 2008 14:51:59 713902 Group = DefaultRAGroup, IP = 213.126.129.250, Removing peer from peer table failed, no match!
pjhenriqs Fri, 01/11/2008 - 08:10
Hey where is your pre-shared key?
tunnel-group remote ipsec-attributes
pre-shared-key *
And what is this?
authentication crack (crack?)
Hope it helps,
Paulo
pjhenriqs Fri, 01/11/2008 - 08:12
Also I think you are missing NAT-T
crypto isakmp nat-traversal 20
husycisco Fri, 01/11/2008 - 08:37
Hi Tristan
Your VPN IP pol and exempt nat rule do not match on netmask
Make the following change
no access-list inside_nat0_outbound extended permit ip any 10.248.2.0 255.255.255.0
access-list inside_nat0_outbound extended permit ip any 10.248.2.0 255.255.0.0
split-tunnel-policy tunnelall
tbrinkma Thu, 01/17/2008 - 03:36
I use the crack because I dont think I can use preshared key as I cannot configure that in the cisco VPN client.
The split-tunnel-policy tunnelall commando doesnt work.
Did configure the nat-t commando.
Still same errors
pjhenriqs Thu, 01/17/2008 - 06:22
You configure a pre-shared key on the profile you create on the Cisco VPN Client. Are you not able to do this?
And this would be enough reason for it not to work, if you have not configured the pre-shared key on your PIX/ASA.
tbrinkma Thu, 01/17/2008 - 07:46
Still nothing.
My current config: (removed not needed lines)
ip local pool Clientpool 10.248.2.0-10.248.2.255 mask 255.255.255.0
no failover
monitor-interface outside
monitor-interface inside
arp timeout 14400
key [Radius secret]
http server enable
encryption 3des
hash sha
group 2
lifetime 86400
address-pool Clientpool
tunnel-group [Name] ipsec-attributes
pre-shared-key *
telnet timeout 5
ssh timeout 5
console timeout 0
parameters
inspect ftp
inspect h323 h225
inspect h323 ras
inspect rsh
inspect rtsp
inspect esmtp
inspect sqlnet
inspect skinny
inspect sunrpc
inspect xdmcp
inspect sip
inspect netbios
inspect tftp
Cryptochecksum:xxx
: end
Logs
3 Jan 17 2008 15:44:45 713902 Group = DefaultRAGroup, IP = x.x.x.x, Removing peer from peer table failed, no match!
4 Jan 17 2008 15:44:45 713903 Group = DefaultRAGroup, IP = x.x.x.x, Error: Unable to remove PeerTblEntry
110 16:45:37.619 01/17/08 Sev=Warning/2 IKE/0xE3000099
Fragmented msg rcvd with no associated SA (PacketReceiver:133)
pjhenriqs Thu, 01/17/2008 - 07:55
You need to add the "interesting traffic". Create your crypto map access-list and assign it to the dynamic crypto map.
Like so...
access-list outside_cryptomap_dyn_20 permit ip any 192.168.2.0 255.255.255.0
crypto dynamic-map outside_dyn_map 20 match address outside_cryptomap_dyn_20
Also add:
sysopt connection permit-ipsec
So that the IPSEC traffic bypasses the access-lists.
Hope it helps,
Paulo
tbrinkma Fri, 01/18/2008 - 04:09
Is the interesting traffic not only for when I use a site-to-site VPN connection. When I use the Cisco client I wouldnt need to use it?
pjhenriqs Fri, 01/18/2008 - 04:16
The interesting traffic is the traffic that will get encrypted in the VPN. Whether that VPN is a site-to-site, remote, DMVPN or whatever, the same principle is applied.
When you use the Cisco client you are using a remote access VPN. How does the firewall know what traffic to encrypt to send the user, if the interesting traffic is not defined?
tbrinkma Fri, 01/18/2008 - 04:29
192.168.2.0 255.255.255.0 is the range of my VPN Clients?
pjhenriqs Fri, 01/18/2008 - 06:24
Yes.
According to your configuration:
HTH,
Paulo
tbrinkma Fri, 01/18/2008 - 06:26
Did put the following lines in it:
access-list outside_cryptomap_dyn_20 permit ip any 10.248.2.0 255.255.255.0
Still nothing...
