4402 controler secure public vlan from private network.
Jan 11th, 2008
I am trying to create a public ssid that goes straight do our pix 501 and out the cable modem without any access to our internal network.
Is this something I can do with an access control list on the 4402 so I can have an address in the say 192.168.1.0 network go straight to our pix and cable modem at say 10.24.16.254 255.0.0.0 ?
SHANNON WYATT Fri, 01/11/2008 - 10:40
The best way would be with a DMZ. If you use the ASA5505 you can do this, but the PIX 501 won't do it. Alternatively you could use ACLs on the Wireless LAN controller, but you would need an additional VLAN.
Trending Topics - Security & Network
