Suggestion req for New implementation
Jan 11th, 2008
Iam having two internet Links of 512kbps & 256 Kbps.
Currently we are using 2mbps bandwidth link for internet sharing.
Can any one suggest any new implementation can be done using these two links which will be recognised ?
regds
mohammedmahmoud Sat, 01/12/2008 - 04:35
  • Green, 3000 points or more
Have you thought about using PBR for specific traffic to use specific link.
BR,
Mohammed Mahmoud.
mtechnology Sat, 01/12/2008 - 09:52
Hi ,
Makes sure that all the three links are connected on to the same router and do the Policy based routing and
Make sure that the Specific traffic getting nat or pat to the specific Firewall before doing the PBR.
Srini
nasheer.ahmad Sun, 01/13/2008 - 20:32
Thanks for your suggestions provided.
But I dont want to link with the same router.I will use a separate router and not to use for Internet Sharing.
some others suggested for Contivity.
How it will be to implement and how to implement ?
regds
shrikar.dange Sun, 01/13/2008 - 21:14
  • Bronze, 100 points or more
hi nasheer,
In my knowledge contivity (Its main use is VPN and Tunneling) is Nortel Networks property,and I am not sure whether you can use it with CISCO router or not.
Can you explain the topology?
HTH,
regards,
shri :)
