Hunt Group back to CRS script
Jan 11th, 2008
  • Bronze, 100 points or more
I'm looking for the most elegant solution. CRS script sends to Hunt group. It matches Successful if it can get at least one HG member ring. If no one answers I'd like to play 30 sec prompt and send it back to HG. I only have QueueManager (no ICD, IP/IVR).
Thanks.
yshraybman Fri, 01/11/2008 - 13:25
I solved it by covering Hunt Pilot to another script.
rcordeiro Sat, 07/05/2008 - 02:11
Hi, I'm trying to achieve the same.
someone calls in listens to a prompt and get the call redirected to a hunt group if no one available plays another prompt and try again after some time.
Can you give me some directions?
RC
honniesr Sat, 07/05/2008 - 19:11
you can setup the maximum hunt timer on the hunt pilot, then set the forward hunt's no answer and busy to another #.
HTH.
Robert
