ASA 5540 to Watchguard VPN
Jan 11th, 2008
I am trying to configure a VPN to a partner company with a watchguard firewall.
I am running a 5540 ASA version 7.2.
It's a pre-shared key config, and passes phase 1. I don't get any debug entries after that and no errors.
A show crypto isakmp sa gives the following:
19 IKE Peer: 64.xxx.xxx.xxx
Type : L2L Role : responder
Rekey : no State : MM_ACTIVE
But a show crypto ipsec doesn't have it listed anywhere.
My crypo config is as follows:
crypto ipsec transform-set ESP-3DES-MD5 esp-3des esp-md5-hmac
crypto ipsec transform-set ESP-3DES-SHA esp-3des esp-sha-hmac
crypto map outside_map 100 match address outside_xxxxx_cryptomap
crypto map outside_map 100 set peer 64.xxx.xxx.xxx
crypto map outside_map 100 set transform-set ESP-3DES-MD5
crypto map outside_map 65535 ipsec-isakmp dynamic outside_dyn_map
crypto map outside_map interface outside
crypto isakmp identity address
crypto isakmp enable outside
crypto isakmp policy 10
authentication pre-share
encryption 3des
hash md5
group 2
lifetime 86400
crypto isakmp policy 30
encryption 3des
hash sha
group 2
lifetime 86400
crypto isakmp policy 40
encryption 3des
hash md5
group 1
lifetime 86400
crypto isakmp nat-traversal 20
My tunnel config is as follows:
tunnel-group 64.xxx.xxx.xxx type ipsec-l2l
tunnel-group 64.xxx.xxx.xxx ipsec-attributes
pre-shared-key *
peer-id-validate nocheck
isakmp keepalive disable
ajagadee Thu, 01/17/2008 - 11:46
  • Cisco Employee,
Can you post the "deb cry is" and "deb cry ipsec" when you try and bring up the tunnel.
Arul
