2811 won't encrypt packets
Jan 11th, 2008
I am trying to bring up a tunnel between my older 2811 and my new ISR 2811. The tunnel shows QM_IDLE with a sho cry isa sa on both devices but I can't ping across the /30 that I assigned to the tunnel interface and sho ip eigrp neigh doesn't show them as neighbors. I have 10 or so tunnels just like this on the older 2811 but this is the first attempt using the newer ISR 2811. I am using firmware version 12.4(15)T1 (C2800NM-ADVIPSERVICESK9-M). When I do a sho cry eng conn active I see decrypts but 0 encrypts. Help..
Danilo Dy Fri, 01/11/2008 - 21:37
Make sure that the VPN ACL is symmetric.
Router-A VPN ACL
Source: Network-A
Destination: Network-B
Router-B ACL
Source: Network-B
Destination: Network-A
Enable this debug in both router and post the output here (check the clock if correct before turning debug on).
Router# debug crypto isakmp
Router# debug crypto isakmp error
Router# debug crypto ipsec
Router# debug crypto pki
Do you have ACL in the interface of VPN Gateway? i.e. "ip access-group ACL# in/out". This ACL should not only include VPN Gateways but also networks permit to travel thru VPN tunnel.
Dandy
cirrushelpdesk Mon, 01/14/2008 - 08:43
from the vpn gateway
access-list 180 permit gre host xxx.xxx.3.70 host 64.209.111.130
from the 2811 ISR
access-list 180 permit gre host 64.209.111.130 host xxx.xxx.3.70
I have a blanket statement to let all VPN related traffic through on my outside facing interface on the vpn gateway both ways. I don't have an ACL yet on the interface on the 2811ISR. This is all I get from the debugs, on the 2811
Jan 14 10:40:32: %CRYPTO-4-RECVD_PKT_NOT_IPSEC: Rec'd packet not an IPSEC packet.
(ip) vrf/dest_addr= /141.131.3.70, src_addr= 64.209.111.130, prot= 47
on the 2811ISR
Jan 14 16:40:48.231: IPSEC(recalculate_mtu): reset sadb_root 47E1CC6C mtu to 1440
Jan 14 16:40:58.232: IPSEC(recalculate_mtu): reset sadb_root 47E1CC6C mtu to 1440
Jan 14 16:41:08.232: IPSEC(recalculate_mtu): reset sadb_root 47E1CC6C mtu to 1440
Jan 14 16:41:18.232: IPSEC(recalculate_mtu): reset sadb_root 47E1CC6C mtu to 1440
Jan 14 16:41:28.233: IPSEC(recalculate_mtu): reset sadb_root 47E1CC6C mtu to 1440
Jan 14 16:41:38.233: IPSEC(recalculate_mtu): reset sadb_root 47E1CC6C mtu to 1440
