TSM Client over Unified Communications
afurtado
I need to know if the client Tivoli TSM can be installed in the same Server Cisco Unity, Cisco IPCC and Cisco Operations Manager. There is some client for the CUCM 5.1?
My customer uses this TSM client for backup the whole datacenter and needs this information.
Thank you very much.
did you get a chance to find out anything about this..my customer wants to use tsm for cucm/unity con 8 to backup..
Cisco does not support third-party utilities for backing up the Cisco CallManager database. Doing so voids your TAC support.
Tip Use the included Cisco IP telephony Applications Backup Utility to back up the Cisco CallManager database to a separate machine. Then, use that separate machine to run your third-party backup software.
Ronak patel
Regards Ronak Patel Rate all helpful post by clicking stars below the answer.
