Does any know if CM 4.2(3) support VWIC2-1MFT-G703
Jan 11th, 2008
Can anyone help or relate their experience with setting up a E1 connection with G.703 on a Cisco 2851 SRST router? I am looking at VWIC2-1MFT-T1/E1 and VWIC2-1MFT-G703 which is both supported on the 2851 but however,I do not see VWIC2-1MFT-G703 supported on CM 4.2(3). Does anyone know if this is possible and if so, can someone point me to the documentation for it.
Paolo Bevilacqua Fri, 01/11/2008 - 10:49
CM doesn't care which hardware you have in the gateway. Just configure MGCP or H.323 as you desire.
Note, is not necessary to use the more expensive G.703 version for VWIC or VWIC2. All version will work fine for voice.
