RME 4.1.0 - CSV reports
Jan 11th, 2008
I've some problem in exporting reports to CSV files. I'm only able to export to PDF.
I'm on a solaris 9, LMS3.0 (RME4.1.0)
For example, opening the "RME Collection Status" > "Failed to Collect" list, following the Export link on the right-top corner, I'm prompted to choose PDF or CSV format. Checking PDF, I've the report generated, but is unuseful; checking CSV, I can see a browser window opening and immediatly closing.
So I've tried to generate some other report from RME > Reports, but with the same result.
regards.
Overall Rating: 1.5 (2 ratings)
Joe Clarke Fri, 01/11/2008 - 11:17
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
I can't reproduce. It sounds like you may have an action tied to .csv files that is failing. You may want to check your file associations for your browser, and see if CSV files are configured to be opened in an non-existent application.
one-ans1357 Sat, 01/12/2008 - 11:52
So you mean my browser isn't able to find an external app to open a .csv file?
Joe Clarke Sat, 01/12/2008 - 12:05
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
No, I mean that your browser is configured to auto-launch an application to open a CSV file, and there is a problem launching that application. When you export to CSV or PDF, the code will open another window which should start the file download. Once the file has been handed off to the browser, Javascript will close the window. At that point, the browser should either present to you a Save As dialog, or open any application that is configured to handle the given MIME type. Another possibility is you have configured CSV files to be auto-saved to a download location.
Since I cannot reproduce your problem, I know there is no systemic issue with the export feature, so I assume there must be some local browser configuration specific to CSV files that can explain what you are seeing.
one-ans1357 Sat, 01/12/2008 - 12:27
Ok, now I understand. Thanks, I'll try to export that report using another pc. I've checked for my IE7 config, but I'll check it again.
I'll tell you.
one-ans1357 Thu, 02/28/2008 - 02:41
Ok, i thank you very much. It was a problem concerning the IE browser.
