%ASA-4-402123: CRYPTO
Jan 11th, 2008
All of a sudden our Port 25 and 443 access went out on our ASA. When trying to connect from the outside we're getting this error. We just need to verify that it's in fact Hardware and not something in the configuration even though the configuration hasn't changed.
%ASA-4-402123: CRYPTO: The ASA hardware accelerator encountered an error (code= 0x15) while executing crypto command 0x30.
Error Message %PIX|ASA-4-402123: CRYPTO: The accel_type hardware accelerator encountered an error (code= error_string) while executing crypto command command .
accel_type-Hardware accelerator type
error_string-Code indicating the type of error
command-Crypto command that generated the error
Explanation This message is displayed when an error is detected while running a crypto command with a hardware accelerator. This could indicate a problem with the accelerator. This type of error may occur for a variety of reasons, and this message supplements the crypto accelerator counters to help determine the cause.
Recommended Action contact the Cisco TAC for assistance
Anyone ever see this error before or can help us out with it?
wjward2 Fri, 02/20/2009 - 10:55
I experienced this same error on an ASA5540 running 8.0(4)terminating SSL VPN.
Have you been able to get any info on this yet?
