CSA 4.5 to 5.2 migration...no workie.
Jan 11th, 2008
All -->
I've copied the 'prepare_45_migration' to the MC running 4.5. When attempting to execute it, I'm prompted with an "Open With..." dialog box - the server doesn't recognize 'prepare_upgrade.csapl'.
This original CSAMC was running 4.0.3 which was inline upgraded to 4.5 about 18 to 24 months ago. We're now looking to migrate the 4.5 info to a new server running 5.2.0.245
Any help is appreciated...
Overall Rating: 5 (1 ratings)
tsteger1 Fri, 01/11/2008 - 13:12
  • Red, 2250 points or more
You should be using prepare_45_migration.exe and should run it in a command window.
That should do the trick.
Tom
astroman Fri, 01/11/2008 - 15:11
That's exactly what I'm doing. I've copied that file to the 4.5 MC, and am trying to simply execute it from a command prompt.
It begins, and then I immediately am prompted with an "Open With..." dialog box...like it doesn't recognize the file type.
It's specifically looking to open a file called 'prepare_migration.csapl' - when I open it with Internet Explorer, it looks like a Perl script.
tsteger1 Fri, 01/11/2008 - 15:38
Sounds like you are doing the right steps.
You may have a Perl issue.
Have a look at migration.log in the C:\Program Files\Cisco Systems\CSAMC\CSAMC(45?)\migration\export folder.
It may contain some clues.
Tom
