lincensing LMS 2.6 after evaluation period terminated
Jan 11th, 2008
Hi folks!
I need to license an LMS 2.6 unix server with license file.
The evaluation period is terminated.
If I cannot open the web interface, how I can update the license file from command line?
Thanks a lot!
Leonardo
Joe Clarke Fri, 01/11/2008 - 15:28
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
The Common Services portion of LMS is unlicensed, so you will be able to login, go to Common Services > Server > Admin > License, and install your new license file without any trouble. The tasks you will not be able to perform are those that are part of other applications such as RME, CM, DFM, and IPM.
