ASK THE EXPERT - CONFIGURING AND TROUBLESHOOTING CISCO AS5X00 ACCESS SERVER
Jan 11th, 2008
Welcome to the Cisco Networking Professionals Ask the Expert conversation. This is an opportunity to get an update on configuration and troubleshooting of Cisco AS5x00 access servers with Cisco expert Zulfiqar Ahmed. Zulfiqar Ahmed, CCIE# 3960, is part of High Touch Technical Support (HTTS) based out of San Jose, California where he currently holds the position of high touch engineer (HTE). Ahmed joined Cisco in 1997 as an engineer in the Technical Assistance Center (TAC). His background has been in Remote Access, Dial, AAA, DSL, and Broadband Cable networks. He has worked on a variety of Cisco Platforms. He has authored relevant Cisco.com documents, conducted trainings and war rooms for Cisco partners, and has taught in Cisco bootcamps and courses.
Remember to use the rating system to let Zulfiqar know if you have received an adequate response.
Zulfiqar might not be able to answer each question due to the volume expected during this event. Our moderators will post many of the unanswered questions in other discussion forums shortly after the event. This event lasts through January 25, 2008. Visit this forum often to view responses to your questions and the questions of other community members.
Overall Rating: 4.5 (2 ratings)
csf129csf129 Sun, 01/13/2008 - 11:06
what do I do when I receive the message "Reason 412:The remote peer is no longer responding."
dinchavan1 Sun, 01/13/2008 - 21:59
hi sir
my name is dinesh chavan
my email ID [email protected] [email protected]
Detail of router configuration and exiting daigram attached
1) I have isp router ,ip address of
lan interface 192.168.10.100
wan interface 59.97.200.23
2)three D-link non manageable switch
3)total 60 computer and ip address range is 192.168.10.100-192.168.10.200 255.255.255.0(it is assing to computer )
I connect port 0 to isp
port 1 to dlink switch
I want install pix 501 into exting network
My plan is
ip address of outside 192.168.10.99 255.255.255.0
ip address of inside 192.168.10.71 255.255.255.0
what is nating/ addistonal configustion
dinchavan1 Sun, 01/13/2008 - 22:38
also I have 506e firewall
hoe to change access and telnet password using telnet
Hi Zulfiquar!
Got a problem with ASA5510/5505 and the packet size.
Infrastructure tests done by my ISP says that they transport up MTU 1500, but on ASA side of my networks (outside) i can only packets of 992b trough??
MTU on the ASA's are set to DSL given 1462.
This causes problems with Citrix/RDP/print/file from my WAN sites and it seems that packets are very fragmented???
Sincerely
Henning Kihle
Norway
internetthomas Wed, 01/16/2008 - 07:13
I have been searching for resources on the file formats for the configuration file and IOS stored in a router or switch but could not identify the formats. Could you help?
Collin Clark Thu, 01/17/2008 - 13:54
PLEASE NOTE THE DISCUSSION IS FOR THE AS5X00 SERIES ACCESS SERVERS AND MEDIA GATEWAYS.
If you are looking for help on the ASA Firewalls, please post to the Firewall forum at http://forum.cisco.com/eforum/servlet/NetProf;jsessionid=077FAD2146A06C1A111291A266565797.SJ3B?page=netprof&forum=Security&topic=Firewalling&CommCmd=MB%3Fcmd%3Ddisplay_messages%26mode%3Dnew%26location%3D.ee6e1fa
Collin Clark Thu, 01/17/2008 - 14:01
Zulfiqar-
We currently have an AS5350 and utilize autocommand telnet. Will Cisco be supporting other protocols in the future (ie FTP)? Will the AS5X00 ever have full IOS services? Thanks.
zahmed Fri, 01/18/2008 - 11:31
Hi Collin,
The command "autocommand" will take any word you enter - be it telnet or FTP. You can enter "autocommand BLAH" under a tty line and it will take it as it and show up in the config.
But what it (the autocommand) will execute is what you can run from the router prompt.
So you can execute a telnet from a router prompt, but obviously not an FTP command. Hence, "autocommand ftp" is not a feasible option.
In other words, "autocommand BLAH" makes sense if and only if BLAH makes sense (from the router or exec prompt).
This is true for any router, be it AS5x00 series or any other platform.
If you could let me know what other IOS services you are referring to for the AS5x00 platform, I can probably answer you with more info.
Thanks and Regards,
~Zulfiqar
zahmed Fri, 01/18/2008 - 10:44
Hi Samuel,
The file format for config files is always TEXT/ASCII. Like in some platforms (not all), you could actually do a "more nvram:startup-config" and "more system:running-config" to give you a config file. And as you know, the 'more' command only works on ASCII files so it's an implicit file format verification technique.
As for IOS stored on on-board FLASH or PCMCIA FLASH devices, the file format depends on the platform. So I would say, for about 90% of the platforms, it's a zip file while for the other 10% it is usually a tar file.
Hope this helps.
Thanks and Regards,
~Zulfiqar
zahmed Fri, 01/18/2008 - 10:45
Hi Samuel,
Hope this helps.
Thanks and Regards,
~Zulfiqar
masonibasis Sun, 01/20/2008 - 17:26
Hi Zulfiqar,
I have an AS5400XM running IOS v12.4(10) that is logging some strange errors:
Jan 12 10:49:21.649 GMT: %SYS-3-MGDTIMER: Master timer has bad magic, timer = 6A155228. -Process= "CC-API_VCM", ipl= 4, pid= 160 -Traceback= 0x6045DCC8 0x605624E8
Jan 13 12:45:50.651 GMT: %SYS-3-MGDTIMER: Master timer has bad magic, timer = 7192EC00. -Process= "CC-API_VCM", ipl= 4, pid= 160 -Traceback= 0x6045DCC8 0x605624E8
Jan 15 12:12:29.822 GMT: %SYS-3-MGDTIMER: Master timer has bad magic, timer = 6F741C4C. -Process= "AFW_application_process", ipl= 4, pid= 48 -Traceback= 0x6045DCC8 0x605624E8
Jan 16 12:00:26.424 GMT: %SYS-3-MGDTIMER: Master timer has bad magic, timer = 6B192FE0. -Process= "AFW_application_process", ipl= 4, pid= 48 -Traceback= 0x6045DCC8 0x605624E8
Jan 17 10:13:20.508 GMT: %SYS-3-MGDTIMER: Master timer has bad magic, timer = 70D36D74. -Process= "AFW_application_process", ipl= 4, pid= 48 -Traceback= 0x6045DCC8 0x605624E8
Jan 18 09:08:05.100 GMT: %SYS-3-MGDTIMER: Master timer has bad magic, timer = 6E7616C8. -Process= "AFW_application_process", ipl= 4, pid= 48 -Traceback= 0x6045DCC8 0x605624E8
Jan 18 09:37:53.009 GMT: %SYS-3-MGDTIMER: Master timer has bad magic, timer = 6C241F70. -Process= "AFW_application_process", ipl= 4, pid= 48 -Traceback= 0x6045DCC8 0x605624E8
Jan 18 11:23:27.227 GMT: %SYS-3-MGDTIMER: Master timer has bad magic, timer = 6B1939F0. -Process= "AFW_application_process", ipl= 4, pid= 48 -Traceback= 0x6045DCC8 0x605624E8
Jan 18 11:34:40.458 GMT: %SYS-3-MGDTIMER: Master timer has bad magic, timer = 7192EA90. -Process= "AFW_application_process", ipl= 4, pid= 48 -Traceback= 0x6045DCC8 0x605624E8
Jan 20 09:30:20.586 GMT: %SYS-3-MGDTIMER: Master timer has bad magic, timer = 6C242530. -Process= "CC-API_VCM", ipl= 4, pid= 160 -Traceback= 0x6045DCC8 0x605624E8
Can you please explain what this error means and what actions should be taken to resolve it?
zahmed Mon, 01/21/2008 - 12:05
Hi Mason,
A "show ver" will be needed to find the exact IOS image filename for this 12.4(10) code for the purpose of decoding the Tracebacks. Only then we will be able to pinpoint to the root cause, however if I have to guess, this sounds like the following software defect :
CSCsl29208 : %SYS-3-MGDTIMER errors seen with voice application
http://www.cisco.com/cgi-bin/Support/Bugtool/onebug.pl?bugid=CSCsl29208&Submit=Search
As you'll see on the above Bug Toolkit link, this defect has been dup'ed to this other defect, CSCsj34095, that is fixed as of 12.4(19) (which is scheduled to be released in early March '08).
Thanks and Regards,
~Zulfiqar
masonibasis Mon, 01/21/2008 - 12:12
Cisco IOS Software, 5400 Software (C5400-IK9S-M), Version 12.4(10), RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2006 by Cisco Systems, Inc.
Compiled Wed 16-Aug-06 06:59 by prod_rel_team
ROM: System Bootstrap, Version 12.3(12r)PI6b, RELEASE SOFTWARE (fc1)
LAX-C03-C5400X-11 uptime is 8 weeks, 6 days, 22 hours, 19 minutes
System returned to ROM by reload at 14:06:54 GMT Tue Feb 22 2000
System restarted at 21:51:36 GMT Mon Nov 19 2007
System image file is "flash:c5400-ik9s-mz.124-10.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
[email protected].
Cisco AS5400XM (BCM) processor (revision 0x22) with 393215K/131072K bytes of memory.
Processor board ID JAE1139Y00R
SB-1 CPU at 750MHz, Implementation 1025, Rev 0.3, 256KB L2 Cache
Last reset from IOS reload
Manufacture Cookie Info:
EEPROM Version 0x4, Board ID 0x4BD,
Board Hardware Version 2.7, Item Number 800-6572547-03,
Board Revision A0, Serial Number JAE1139Y00R.
Processor 0x0, MAC Address 001b.d51b.5280
2 Gigabit Ethernet interfaces
512 Serial interfaces
648 terminal lines
28 Channelized T1/PRI ports
1 Channelized T3 port
512K bytes of NVRAM.
125440K bytes of ATA External CompactFlash (Read/Write)
zahmed Mon, 01/21/2008 - 12:20
Mason,
Thanks for providing the 'show ver'. It indeed is the above mentioned defect(s) I mentioned.
Thanks and Regards,
~Zulfiqar
joe-vieira Tue, 01/22/2008 - 11:10
We have a 5350xm configured for dial in clients using Cisco ACS for authentication. Now we have a need to use tokens instead of passwords. Do you have documentation on how to configure this solution from the client to the 5350 to the token server and back?
thanks
joe-vieira Wed, 01/23/2008 - 10:13
The thing is we're not using ISDN, we're using regular phone lines and we're also using the Windows XP dialer. Is it possible for the dialer at the PC to access the rsa usb token, prompt for the pin and then connect through the AS5350 to the servers?
zahmed Fri, 01/25/2008 - 12:12
Joe,
Sorry to have misunderstood your question earlier.
As for doing SecureID authentication for your async/modem clients, there is not much that you need to configure on the the access server.
As always, you will configure your T1 controller(s), the group-async interface, the "aaa new-model" section, and "line x y" (or the tty line config) section as you normally would for a PPP dialin application. Just make sure you have "autoselect ppp", "autoselect during-login", and "autocommand ppp" defined as well under the tty lines.
This is a very common scenario and
all Windows clients support it if you enable
"terminal window after dialing"
method - which is the character mode username authentication before PPP starts.
Basically, , first the user is presented an EXEC prompt and thereafter PPP is automatically started at successful login. That means that the user must bring up the terminal screen after dialin.
Hope this helps.
Thanks and Regards,
~Zulfiqar
joe-vieira Fri, 01/25/2008 - 12:16
Sorry but what is the terminal screen for? Does it prompt for a pin number related to the usb token?
g.pregnolato Thu, 01/24/2008 - 03:57
I'd like to know the cabling specification for the 8-Port E1 Feature Card for AS5400XM.
In my implementation I've an UTP cable (10/15 mt. of length) connected to the AS5400XM and a CAB adapter 75-120 ohm connected to the telephone permutator. In the output of the "show controller e1" (in the attachment) you can find some errors that I suppose are related to cabling. The ECCVGBO3_old contains the output with the old cabling. With the new cabling (ECCVGBO3_new) the errors are decreased but don't disappear (for example e1 7/7).
I have some question for you:
1) Is it required that the cable from the telephone permutator to the AS5400XM is a coax cable with the cab adapter near to the router (short UTP cable)?
2) In the "show controller e1" output are showed only the input error?
3) Is it possible to decrease the error rate with some configuration of the controllers (for example adjusting the cable-length parameter)?
Tanks.
zahmed Fri, 01/25/2008 - 12:26
Hi Giuseppe,
Please see Table A-11 in the following doc for cabling spec for the 8 port E1 DFC :
http://www.cisco.com/en/US/docs/routers/access/as5350/hardware/interfaces/guide/54crdcbl.html#wpxref49389
For your question whether or not you need short UTP cable, I suggest you open up a TAC case to confirm that.
As for the input errors, that is only viewable
on the corresponding "show interface Ser x/y:15" output.
And yes, you might want to play with the cable-length command but if it does not do any good, you will have to get the E1 checked by your provider which is what it looks to me that might have to be done eventually.
Thanks and Regards,
~Zulfiqar
masonibasis Thu, 01/24/2008 - 11:14
Hi Zulfiqar,
I have an AS5300 that is dropping calls on a single ISDN PRI E1. Calls on the other E1s are completing fine. Can you please offer any insight as to why this might be happening? Please let me know if you need additional information.
sh ver and debug output:
LON-AP1-C5300-4#sh ver
IOS (tm) 5300 Software (C5300-IK9S-M), Version 12.3(22), RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2007 by cisco Systems, Inc.
Compiled Wed 24-Jan-07 19:36 by ccai
Image text-base: 0x60008AEC, data-base: 0x61854000
ROM: System Bootstrap, Version 12.0(2)XD1, EARLY DEPLOYMENT RELEASE SOFTWARE (fc1)
BOOTLDR: 5300 Software (C5300-BOOT-M), Version 12.0(4)T1, RELEASE SOFTWARE (fc1)
LON-AP1-C5300-4 uptime is 27 weeks, 1 day, 10 hours, 14 minutes
System returned to ROM by reload at 08:49:48 GMT Wed Jul 18 2007
System restarted at 08:50:39 GMT Wed Jul 18 2007
System image file is "flash:c5300-ik9s-mz.123-22.bin"
cisco AS5300 (R4K) processor (revision A.32) with 131072K/16384K bytes of memory.
Processor board ID 14898474
R4700 CPU at 150MHz, Implementation 33, Rev 1.0, 512KB L2 Cache
Channelized E1, Version 1.0.
Bridging software.
X.25 software, Version 3.0.0.
SuperLAT software (copyright 1990 by Meridian Technology Corp).
Primary Rate ISDN software, Version 1.1.
Backplane revision 2
EEPROM Type 0x0001, EEPROM Version 0x01, Board ID 0x30,
Board Hardware Version 1.80, Item Number 800-2544-03,
Board Revision A0, Serial Number 14898474,
PLD/ISP Version 0.0, Manufacture Date 8-Jul-1999.
1 Ethernet/IEEE 802.3 interface(s)
1 FastEthernet/IEEE 802.3 interface(s)
126 Serial network interface(s)
4 Channelized E1/PRI port(s)
60 DSP(s), 120 Voice resource(s)
128K bytes of non-volatile configuration memory.
16384K bytes of processor board System flash (Read/Write)
8192K bytes of processor board Boot flash (Read/Write)
LON-AP1-C5300-4#deb isdn error int Serial0:15
Jan 24 19:04:02.166 GMT: ISDN Se0:15 SERROR: call_cleared: Got a disconnect on a non-existent call (call id = 0xCD2C).
This probably is a call that we placed that failed.
Jan 24 19:04:02.166 GMT: ISDN Se0:15 **ERROR**: call_cleared: VOICE ERROR: NULL VDEV Common(0xFC): bchan -1, call id 0xCD2C
Jan 24 19:04:06.218 GMT: ISDN Se0:15 SERROR: call_cleared: Got a disconnect on a non-existent call (call id = 0xCD2D).
Jan 24 19:04:06.218 GMT: ISDN Se0:15 **ERROR**: call_cleared: VOICE ERROR: NULL VDEV Common(0xFC): bchan -1, call id 0xCD2D
Jan 24 19:04:12.866 GMT: ISDN Se0:15 SERROR: call_cleared: Got a disconnect on a non-existent call (call id = 0xCD30).
Jan 24 19:04:12.866 GMT: ISDN Se0:15 **ERROR**: call_cleared: VOICE ERROR: NULL VDEV Common(0xFC): bchan -1, call id 0xCD30
Jan 24 19:04:15.050 GMT: ISDN Se0:15 SERROR: call_cleared: Got a disconnect on a non-existent call (call id = 0xCD32).
LON-AP1-C5300-4#deb isdn q931 asn1 interface Serial0:15
debug isdn asn1 is ON.
Jan 24 18:56:46.139 GMT: ISDN Se0:15 **ERROR**: call_cleared: VOICE ERROR: NULL VDEV Common(0xFC): bchan -1, call id 0xCC0E
Jan 24 18:56:48.219 GMT: ISDN Se0:15 **ERROR**: call_cleared: VOICE ERROR: NULL VDEV Common(0xFC): bchan -1, call id 0xCC0F
Jan 24 18:56:48.891 GMT: ISDN Se0:15 **ERROR**: call_cleared: VOICE ERROR: NULL VDEV Common(0xFC): bchan -1, call id 0xCC10
Jan 24 18:56:51.711 GMT: ISDN Se0:15 **ERROR**: call_cleared: VOICE ERROR: NULL VDEV Common(0xFC): bchan -1, call id 0xCC11
Jan 24 18:56:53.691 GMT: ISDN Se0:15 **ERROR**: call_cleared: VOICE ERROR: NULL VDEV Common(0xFC): bchan -1, call id 0xCC13
Jan 24 18:56:54.799 GMT: ISDN Se0:15 **ERROR**: call_cleared: VOICE ERROR: NULL VDEV Common(0xFC): bchan -1, call id 0xCC15
zahmed Fri, 01/25/2008 - 12:35
Hi Mason,
A full capture of debug isdn q931, debug isdn event, and debug ppp nego will be required in addition to the relevant config. But are you sure calls are indeed dropping on this particular PRI that you mentioned and are not like this cosmetic issue :
CSCse55246
Unnecessary message printed**ERROR**: call_progress: DEV_CONNECTED VOICE
You might want to get a TAC case open for further investigation.
Thanks and Regards,
~Zulfiqar
