One way audio issue
mightyking
Level 6
Level 6
Hello Folks,
We have one way audio issue. When I Receive/Make a call from the IP phone nobody can hear me but I can hear the other end very well. I know most of the time this is an routing misconfiguration but I don't seem to be able to figure out where the problem is. Any help would be greately appreciated. I am uploading the config for Switch where the phone is contected and the GW contected to the PSTN.
CCM 5.1
GateWay (C3845-SPSERVICESK9-M), Version 12.4(15)T1
Access Switch (C3750-IPBASEK9-M), Version 12.2(25)SEE2
MK
8 Replies 8
gogasca
Level 10
Level 10
Hi MK,
mgcp bind control source-interface GigabitEthernet0/0
You can try to bind media as well in MGCP GW
and make sure there is IP connectivity from
the interfaces you bind. (Do an extended ping from IOS GW)
interface Loopback0
ip address 10.1.1.1 255.255.255.0
description $ETH-LAN$$ETH-SW-LAUNCH$$INTF-INFO-GE 0/0$
ip address 10.16.8.253 255.255.255.0
duplex auto
speed auto
media-type rj45
Thanks Gogasca,
I double checked there's no issue with the IP conectivity. You just repeated the config that I had posted in your reply but you don't say if there's anything wrong with it. Is there anything wrong with the interfaces and the mgcp bind config?
MK
"You can try to bind media as well in MGCP GW "
add the mgcp bind media command otherwise u may start thinking in opening a case with us and gather sniffer capture
What he's trying to say is, make the MGCP section of the config look like this:
mgcp
mgcp call-agent 10.16.8.14 2427 service-type mgcp version 0.1
mgcp rtp unreachable timeout 1000 action notify
mgcp modem passthrough voip mode nse
mgcp package-capability rtp-package
mgcp package-capability sst-package
mgcp package-capability pre-package
no mgcp package-capability res-package
no mgcp package-capability fxr-package
no mgcp timer receive-rtcp
mgcp sdp simple
mgcp fax t38 inhibit
mgcp rtp payload-type g726r16 static
mgcp bind media source-interface GigabitEthernet0/0
mgcp profile default
Thanks GONZALO and David, I appreciate your help.
The one way audio has been resolved. The other end hears me now but I hear back whatever I say in my earpiece. Is there anything that I am missing in the configuration?
MK
Hi MK
Sorry for not being so clear in my previous posts. But since you are using FXOs you may check this URL to reduce echo.
http://www.cisco.com/en/US/tech/tk652/tk698/technologies_tech_note09186a0080149a1f.shtml#ipphoneecho
Thanks for the reply. The problem that I have is with PRI trunks and not with FXO lines. I would appreciate if you can help me out.
MK
If you're using PRI then I would try a diffent headset. I highly recommend plantronics headset. I also have seen issue like this with phones on external power supply.
Hope that helps.
Danny
