Link aggregating
Jan 11th, 2008
(this is for ports 17-18 config in group 1)
switch(config)#int fa0/17
switch(config-if)#switchport mode access
switch(config-if)#switchport access vlan 1
switch(config-if)#channel-group 1 mode active
switch(config)#port-channel load-balance src-mac
(this is for ports 19-20 in group 2)
switch(config)#int fa0/19
switch(config-if)#channel-group 2 mode active
Im trying to configure my ports in catalyst switch 2950. Port 17-18 belong to group 1 and ports 19-20 belongs to group 2.
My concern is, if my configuration is enough in configuring my lacp.
glen.grant Sat, 01/12/2008 - 05:21
  • Purple, 4500 points or more
Looks good to me , You have to make sure the far end looks exactly the same except the load balance doesn't have to be the same if you don't want it to . The channel groups don't have to match either though I think it is better if you do just from a troubleshotting perspective , also put in your description field on each port where the other end is going for ease of troubleshooting.
mohammedmahmoud Sat, 01/12/2008 - 05:37
  • Green, 3000 points or more
Please don't forget to shutdown the interfaces before configuring the etherchannel (or they'll enter err-disable - when it is configured only on one side (misconfig) it will be err-disabled to prevent any spanning tree loops) - shutdown only one side until doing the configuration on both sides does the trick.
BR,
Mohammed Mahmoud.
