SNMP Lost in Tunnel
Jan 12th, 2008
Hey. We have an Pix 525 as our main applicance. With satellite sites running Pix 506e. All communications are tunneled thru a 3725 router. We we lost communications due to power failure and when we checked configs we found that three of our devices are not manageable. Satellite device can not be reach via telnet nor can it tracroute, nor is it possible to communicate with either inside/outside the 506e. Once you console into the device you can ping out to any location.
This one has me?
jsivulka Fri, 01/18/2008 - 06:29
Satellite device can be reach via telnet or by tracroute command. From the problem descrition I think that is a problem about routes because when you do a extended ping you are selecting the source interface.
Understanding the Ping and Traceroute Commands :
