VPN concentrator and webVPN
Jan 12th, 2008
  • Silver, 250 points or more
Trying to setup VPNc 3005 for WebVPN.
The VPNc is configured with NTP server so
the clock is fine. I installed SSL vpn
client and SecureDesktop software onto the VPNc. Create a local account and
group. When I perform https://vpnc/admin.html, I can manage the
VPNc from the external interface so the
certificate is good.
When I do http://vpnc from the same XP Service Pack 2 workstation, it attemped
to install both ssl vpn client and secure desktop onto my winXP, I have admin privilege on the XP machine, then
it tells me that the vpn concentrator
has a server certificate error. I've
attached the screen shot. Anyone know
what it is? Thanks.
ebreniz Fri, 01/18/2008 - 07:20
If you connect to a website that loads content (such as images) from a second, previously unauthenticated server, the content might not be rendered correctly. WebVPN clientless mode does not support websites that require authentication for access to content from secondary servers. When using WebVPN with NAT-T, do not set the NAT-T port to 443. We recommend using port 80 for NAT-T, as firewalls should allow this.
http://www.cisco.com/en/US/docs/security/vpn3000/vpn3000_41/configuration/guide/webvpnap.html
http://www.cisco.com/en/US/docs/security/vpn3000/vpn3000_41/quick/start/gs3mgr.html#wp1302684
