DLCIs over WAN link to seperate VRF traffic management
Jan 12th, 2008
Dear all,
I have the scenario where CE is connecting to PE with one serial interface and have multiple DLCIs. Each DLCI is assigned to seperate VRF on PE.
Now my question is how to control priority between each DLCI, for example, appA on dlci 100 might need high priority from appB on dlci200 that are on diffent VRF.
Monty
mounir.mohamed Sun, 01/13/2008 - 01:33
  • Gold, 750 points or more
I beleive FRTS neasted with policy-map can solve your issue.
swaroop.potdar Wed, 01/16/2008 - 12:21
  • Blue, 1500 points or more
Monty,
you may want to take a look at fram-realy dlci prioritization on an interface command.
interface serial4.1 multipoint
ip address 172.16.1.1 255.255.255.0
frame-relay priority-dlci-group 3 200 210 300 300
frame-relay priority-dlci-group 4 400 410 410 410
frame-relay interface-dlci 200
frame-relay interface-dlci 400
Here is the command reference.
http://www.cisco.com/en/US/products/sw/iosswrel/ps5207/products_command_reference_chapter09186a00801a7f4c.html#wp1074505
HTH-Cheers,
Swaroop
m.noktes Thu, 01/17/2008 - 06:04
Thanks for reply, I am wondering if this feature can apply to DLCI on different subinterface? I have not lap it up yet.
Cheers,
Monty
