Log File Message
Jan 12th, 2008
Wanted some opinions
3|Jan 12 2008 07:48:14|313001: Denied ICMP type=3, code=13 from 12.126.158.81 on interface outside
6|Jan 12 2008 07:48:19|113015: AAA user authentication Rejected : reason = Invalid password : local database : user = root
6|Jan 12 2008 07:48:19|611102: User authentication failed: Uname: root
1cmerchant Mon, 01/14/2008 - 05:35
In short I believe this message simply says that someone (or some script) was attempting to log into your device on it's Outside interface. If you don't require access to your device from the Outside, simply disable ssh logins.
