PIX 515E 8.0 Password recovery
Answered Question
So, I have a PIX 8.0 that I will have to perform password recovery on, and am not finding what I need. I have done pw recovery on other versions of PIX before using the "npXX.bin" files, and I found the following documentation for 8.0:
http://www.cisco.com/en/US/docs/security/asa/asa80/configuration/guide/trouble.html#wp1065915
The problem is that the documentation says to use a "npXX.bin" file just like in the past, but the latest version of that file that is available is "np70.bin".
Can I use "np70.bin" for a 8.0 PIX, or what?
Jeff
Correct Answer by mcwalter about 9 years 3 months ago
I used np70.bin on a Pix515E running 8.0(3) code and it worked fine. TAC said np70.bin was for "later versions" of code, not just 7.0. It was a snap.
Good luck.
Overall Rating: 5 (2 ratings)
JORGE RODRIGUEZ Sun, 01/13/2008 - 12:31
  • Green, 3000 points or more
Jeff, good question .. Im replying to this message so it does not loose its momentun in forum. I confirmed as you have all password recovery for cisco PIX covers version 7.x but nothing mentioned on 8.0x or any other link I could fine indicating the ok to use np70 on PIX platforms running 8.0.To be completely sure I would suggest that you open a TAC case to receive confirmation from them or additional link with accurate process information.
Rgds
Jorge
Correct Answer
mcwalter Sun, 01/13/2008 - 16:45
Good luck.
