Multilink with 4 T1's
Jan 12th, 2008
Experts ,
Our ISP has provided with a sample configuration to setup a point to point Multilink T1 connection btw two office's.
controller T1 0/0
framing esf
clock source line primary
linecode b8zs
channel-group 0 timeslots 1-24 speed 64
controller T1 0/1
framing esf
linecode b8zs
interface Multilink1
ip address 160.81.xx.xx 255.255.255.252
no ip proxy-arp
load-interval 30
no peer neighbor-route
ppp chap hostname group1
ppp multilink
ppp multilink fragment disable
ppp multilink group 1
interface FastEthernet0/0
ip address 192.160.xx.xx 255.255.255.0
speed auto
full-duplex
no mop enabled
interface Serial0/0:0
bandwidth 1536
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
encapsulation ppp
load-interval 30
ppp multilink
interface FastEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface Serial0/1:0
bandwidth 1536
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
encapsulation ppp
load-interval 30
ppp multilink
interface Serial0/2:0
bandwidth 1536
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
encapsulation ppp
load-interval 30
ppp multilink
I have pasted only relevant part of config , the question that i have is , i see that controller T1 0/0 , has "clock source Primary" , however i don't see the same command for other T1 controllers , is that ok or ISP missed to put that command for second Controller T 0/1
Any help will be appreciated
Overall Rating: 4 (1 ratings)
Hieu Cao Tue, 01/15/2008 - 16:53
There are 2 kinds of clock sources: internal and line (default=line). You can add the command "clock source line" to the second controller if you want.
Type "show controller t1" to view the current controller status and other related information.
chris_tan Tue, 01/15/2008 - 17:46
Hi, best idea is to confirm the correct "clock source" with your ISP. The link might not work if you have different setting on either site.
You can refer to the url provided by ediortiz on what type of source and the command. Hope it solve your doubt.
