01-12-2008 11:55 AM - edited 03-05-2019 08:25 PM
dear Netpro!
what this Mean?
In the Network EIGRP 1 is configured , you must transit the EIGRP to ospf smoothly.
many 10xs
Solved! Go to Solution.
01-12-2008 12:11 PM
route-map is recommended on redistribution since you can control what routes are injected into the protocol.
If you don't use route-map, all routes from the source protocol gets injected into the destination protocol.
01-12-2008 12:02 PM
Hi Ali,
It's this a task from a workbook ? I don't understand the question well but I believe they want you to redistribute EIGRP into OSPF and I guess you should redistribute OSPF into EIGRP as well.
HTH,
__
Edison.
01-12-2008 12:07 PM
10xs Edison!
in if we have router runing to dynamic protocol now in wich cases we have to use route-map in the redisr?
10xs
01-12-2008 12:11 PM
