Edison Ortiz Sat, 01/12/2008 - 15:40
  • Hall of Fame,
    Founding Member
Please post the output from typing:
show ip int brief | ex una
and
show spanning-tree
where are you pinging from and where are you pinging to ?
__
Edison.
Edison Ortiz Sat, 01/12/2008 - 15:58
  • Hall of Fame,
    Founding Member
Bridge group 50 is executing the ieee compatible Spanning Tree protocol
Bridge Identifier has priority 32768, address 001b.2adf.6ba8
Configured hello time 2, max age 20, forward delay 15
We are the root of the spanning tree
Topology change flag not set, detected flag not set
Number of topology changes 1 last change occurred 03:33:03 ago
from Vlan1
Times: hold 1, topology change 35, notification 2
hello 2, max age 20, forward delay 15
Timers: hello 0, topology change 0, notification 0, aging 300
Port 2 (FastEthernet0/0) of Bridge group 50 is down
Port path cost 19, Port priority 128, Port Identifier 128.2.
Designated root has priority 32768, address 001b.2adf.6ba8
Designated bridge has priority 32768, address 001b.2adf.6ba8
Designated port id is 128.2, designated path cost 0
Timers: message age 0, forward delay 0, hold 0
Number of transitions to forwarding state: 0
BPDU: sent 0, received 0
Port 3 (FastEthernet0/1) of Bridge group 50 is down
Port path cost 19, Port priority 128, Port Identifier 128.3.
Designated port id is 128.3, designated path cost 0
___
What's connected on those ports ?
If you want to ping interface BVI 50, one of these ports need to be up.
avionics Sat, 01/12/2008 - 16:05
at the present nothing is connected. i have a device connected to fa1/7 but am unable to ping that device. the device i am trying to ping is 10.10.1.1 shouldnt i be able to do this?
avionics Sat, 01/12/2008 - 16:06
sorry im all confused the device i am trying to ping is connected to fa1/0.
Edison Ortiz Sat, 01/12/2008 - 18:56
  • Hall of Fame,
    Founding Member
That's Vlan 100. This router doesn't have any IP on Vlan 100 so it needs a device to route from Vlan 50 (which is the only IP from the switch) to Vlan 100.
