was studying for exam 640-821-now defunct
Jan 12th, 2008
the book I was studying was CCNA intro sybex press todd lammle 640-821 ..what is the feed back on having to buy a new book on the test or continue on with this book , and taking the test 640-822?
thanks..
Hi There
I would suggest having a look on the CCNA Prep Center site http://www.cisco.com/web/learning/le3/current_exams/640-822.html for the 640-822 exam and check out what is going to be covered. Then see if the sybex book you are using covers all this material.
If not you might find the information on what is missing free on the Cisco site or even elsewhere on the web.
If not you might want to consider picking up another book which does cover all the required topics.
Best Regards & Good Luck with the studies,
Michael
