642-642 Policing Question
Answered Question
Jan 13th, 2008
In preparation for 642-642 can anyone help me by advising what the default actions are when using the policing command?
For example a three-colour policer can be set up by manually configuring values for Bc and Be however the violate-action is optional. If you configure Bc and Be but specify no violate-action, what does a router do with violating traffic?
Similary, Example 6-10 in the Exam Certification Guide shows the command:
police cir percent 25 bc 500 ms pir percent 50 be 500 ms
What are the default conforming and exceeding actions in this case?
Any help greatly appreciated.
Many thanks,
Mike
Correct Answer by mounir.mohamed about 9 years 1 month ago
Simply, The default conform action is Transmit, while the default exceeding action = DROP
In the first example, any exceeding traffic (Traffic over the CIR / over conform) will be treat as per the exceeding action (default = drop)
In the second example the Conform action will be taken for the traffic that equal or less than the CIR (Default = Transmit), exceeding action will taken based on the value of PIR (default = drop)
policy-map test
class test
R5#show policy-map test
Policy Map test
Class test
conform-action transmit
exceed-action drop
violate-action drop
Pls rate helpful posts.
Best Regards,
Mounir Mohamed
Overall Rating: 5 (2 ratings)
Correct Answer
mounir.mohamed Sun, 01/13/2008 - 12:26
policy-map test
class test
Policy Map test
Class test
exceed-action drop
violate-action drop
Best Regards,
Mounir Mohamed
mike_riggall Sun, 01/13/2008 - 15:26
Many thanks for your clear explanation which makes perfect sense of course.
I think perhaps the moral of the thread is that it helps to have access to a router to try these things on!
Best regards,
Mike
