how to limit the traiffc on 3750 switch
Jan 13th, 2008
we need to limit the traffic passing throught one of ports of our 3750 switch, for example, the port speed limit to 1M, how to implement that? thanks in advance
Overall Rating: 3.7 (3 ratings)
Edison Ortiz Sun, 01/13/2008 - 10:23
  • Hall of Fame,
    Founding Member
The command recommended by Massimiliano will definitely give you what you want, however it's best to understand all other QoS components in the 3750, so check out the full document on the subject at:
http://www.cisco.com/en/US/docs/switches/lan/catalyst3750/software/release/12.2_35_se/configuration/guide/swqos.html
HTH,
__
Edison.
shibindong Sun, 01/20/2008 - 19:25
thanks for both of you, what if i try to limit the traffic below 1M? say, 128K?
Edison Ortiz Mon, 01/21/2008 - 09:59
  • Hall of Fame,
    Founding Member
On a L3 or L2 switchport ?
__
Edison.
Edison Ortiz Tue, 01/22/2008 - 06:22
  • Hall of Fame,
    Founding Member
You need rate-limit
rate-limit output 128000 14000 14000 conform-action transmit exceed-action drop
shibindong Wed, 01/23/2008 - 07:36
i think this can only limit the traffic to 1M because the minimum parameter is 10 percent, my question is: how to configure lower than 1M, say 128K?
Edison Ortiz Thu, 01/24/2008 - 16:46
  • Hall of Fame,
    Founding Member
You can't with Layer2 switchports.
