Jan 13th, 2008
if I'm on SRST mode the ATA won't register with the GW, is there a few lines that I'm missing or what should I do in order to get the ATA to register with CCM
I have a 2851 GW running Version 12.4(3h)
e.huntley Mon, 01/14/2008 - 06:27
To start with the easy you have your ATA's in the same device pool as your phones. If not make sure the device pool they are in have the proper SRST reference.
Aaron Dhiman Mon, 01/14/2008 - 07:04
Are they in the same VLAN as your phones, and are you using "strict-match" in the "ip source" statement for call-manager-fallback?
cris_jimenez Mon, 01/14/2008 - 08:03
I'm not using the strict-match
this is what i have
ip source-address port 2000
Aaron Dhiman Mon, 01/14/2008 - 08:09
Is it in the voice VLAN? If you are using "Default Gateway" for SRST, you need to make sure that the default gateway is the gateway with SRST on it...
cris_jimenez Mon, 01/14/2008 - 09:04
yes, the ATAs are in the voice vlan
I'm not using a default gateway
secondary-dialtone 9
max-conferences 8 gain -6
max-ephones 75
max-dn 100
transfer-pattern 7070..
voicemail 919169333324
multicast moh port 16386 route
toormehdi Fri, 06/26/2009 - 08:07
I am having the similar issue although the IOS is latest...Were you ever able to figure this out?
Thanks in advance
