ohassairi Sun, 01/13/2008 - 23:20
conf t
interface fast 0/0
no shut
exit
interface fast 0/1
ip address 192.168.2.1 255.255.255.0
no shut
exit
then connect a PC to fast 0/0 (if directly use cross cable) and give it the IP 192.168.1.2 255.255.255.0 gateway: 192.168.1.1
then connect a PC to fast 0/1 (if directly use cross cable) and give it the IP 192.168.2.2 255.255.255.0 gateway: 192.168.2.1.
both computer should be able to ping each other
