SSL Termination & Cert Managament on CSS11501 / 11503
Answered Question
Jan 13th, 2008
Hi there....I have successfully implemented an SSL terminated site on the CSS, and load balanced to backend servers using HTTP. It all works great. This is on an 11501 w/SSL Module.
My question is, how do I add another complete SSL terminated site on the same 11501? When I just tried to duplicate the config for the existing SSL server and modify the required fields, I got an error saying:
%% Can only have one active sslAccel type of service per slot.
It has different certs, different VIP, different services, etc...
Also, after I get this working in our test environment, I will be implementing it in prod on a pair of redundant 11503's w/ SSL Modules. Can the 11503 w/SSL Mod handle more certs and SSL servers etc?
Please advise
Sandeep
Correct Answer by Gilles Dufour about 9 years 2 months ago
It's the same for all CSS1150x.
Gilles.
Sandeep,
you can have only one ssl-proxy-list as indicated by the message.
But inside the proxy-list you can configure multiple server.
So when you want to add a new "site" you need to add new servers to the proxy-list and reuse the proxy-list in the new content rule.
Gilles.
Overall Rating: 5 (2 ratings)
Correct Answer
Gilles Dufour Mon, 01/14/2008 - 01:06
  • Cisco Employee,
Sandeep,
Gilles.
yycsandman007 Tue, 01/15/2008 - 08:20
excellent....thanks! Is that the same case also for the 11503?
Sandeep
Correct Answer
Gilles Dufour Wed, 01/16/2008 - 00:17
  • Cisco Employee,
Gilles.
