missing config/ can not add it too
Jan 13th, 2008
Team,
I have a 6509, and a WS-F6K-MSFC2,
when i do show run, i see no config for module 15, which is where the msfc is:
here is the current output:
compared whith what i had in the backup output of show run, few days ago:
#module 9 empty
#module 15 : 1-port Multilayer Switch Feature Card
#module 16 empty
BEFORE:
#module 9 empty
set module name 15
set module enable 15
set vlan 1 15/1
set port name 15/1
set cdp enable 15/1
set trunk 15/1 nonegotiate isl 1-1005,1025-4094
set spantree portcost 15/1 4
set spantree portpri 15/1 32
set spantree portvlanpri 15/1 0
set spantree portvlancost 15/1 cost 3
set spantree guard none 15/1
set port gmrp 15/1 enable
set gmrp registration normal 15/1
set gmrp fwdall disable 15/1
#module 16 empty
the customer did replace the chassis, and the sup, but not the MSFC,
and I can not add that config in,
i get the following when i try to add it fromthe backup above:
MSP-OP5DTESTSWA> (enable) set mod ena 15
Feature not supported on Module 15.
anyone seen this before ?
the reason the customer replaced that HW, because the switch was reloading.
here is an outpout of show mod too for your view:
(enable) sh mod
Mod Slot Ports Module-Type Model Sub Status
1 1 2 1000BaseX Supervisor WS-X6K-SUP1A-2GE yes ok
15 1 1 Multilayer Switch Feature WS-F6K-MSFC2 no ok
3 3 8 1000BaseX Ethernet WS-X6408A-GBIC no ok
4 4 8 1000BaseX Ethernet WS-X6408A-GBIC no ok
5 5 48 10/100BaseTX Ethernet WS-X6348-RJ-45 no ok
Mod Module-Name Serial-Num
1 SAD05010NJK
15 SAD05020798
3 SAD04470M6U
4 SAD05010BUM
5 SAL04440VVF
Mod MAC-Address(es) Hw Fw Sw
1 00-04-c0-f8-41-e6 to 00-04-c0-f8-41-e7 7.0 5.3(1) 6.4(17)
00-04-c0-f8-41-e4 to 00-04-c0-f8-41-e5
00-0c-86-a2-3e-80 to 00-0c-86-a2-42-7f
15 00-04-c1-cc-bf-80 to 00-04-c1-cc-bf-bf 1.1 12.1(8b)E1 12.1(8b)E19
3 00-02-fc-22-1d-d8 to 00-02-fc-22-1d-df 1.3 5.4(2) 6.4(17)
4 00-03-32-b9-93-9e to 00-03-32-b9-93-a5 1.3 5.4(2) 6.4(17)
5 00-03-6c-29-65-f0 to 00-03-6c-29-66-1f 1.4 5.4(2) 6.4(17)
Mod Sub-Type Sub-Model Sub-Serial Sub-Hw
1 L3 Switching Engine WS-F6K-PFC SAD0501037J 1.1
glen.grant Sun, 01/13/2008 - 17:23
  • Purple, 4500 points or more
You have to "session " into module 15 , which basically telnetting into module 15 . Here you put in your userid and password. This is where all your layer 3 config info is . You are running a hybrid box which is catos on the layer 2 side and IOS on the layer 3 side . You are looking at the layer2 side . Hopefully you saved your layer 3 config before replacing the module. If he replaced the supervisor he replaced the msfc also or he would have had to unplug the msfc module from the current supervisor because it is a daughter card on the supervisor.
