To get internet access, I need to make a VPN connection to a Cisco concentrator. For that I have the choice between PPTP (with a very limited bandwidth) or IPSec with the Cisco VPN Client.
Now I want to make a second VPN connection (PPTP or OpenVPN) over the first one. When I use PPTP for the first one, the second one is working fine (but as I said the bandwidth is very limited).
When I use the Cisco VPN Client as my first connection (which I prefer), I can also make the second connection (both with PPTP and OpenVPN), but in the status window in Vista I see "limited connectivity" and no internet access is possible anymore. Does anybody know if this is a limitation from the Cisco Client? Is there a workaround for this?
Thank you very much.
Thomas Vandevyvere
