VLAn and VTP configuration..
Jan 13th, 2008
Hi can you please check if my configuration below is correct or do you have any suggestion?
I have 3550 and 1 2960, the 2960 will connect on 3550 using VTP and with VLAn configuration. please check below my config.
3550 configuration
config t
vtp domain cisco.com
vtp passord cisco
vtp mode server
config t
int vlan 2
ip address 153.117.183.1 255.255.255.240
no shut
end
config t
int fa0/48
switch port trunk encapsulation dot1q switchport mode trunk
exit
2960 configuration
config t
vtp passord cisco
vtp mode client
config t
int vlan 2
ip address 153.117.183.2 255.255.255.240
no shut
end
config t
vlan 2
name WIP_clients
exit
config t
int fa0/3
switchport mode access
witchport access vlan2
end
int fa0/4
switchport access vlan2
end
int fa0/5
end
int fa0/6
end
config t
int fa0/1
end
Overall Rating: 3 (1 ratings)
glen.grant Sun, 01/13/2008 - 18:25
  • Purple, 4500 points or more
Make sure you make the layer 2 bvlan on the 3550 also , besides that it looks like it should work . Myself I would make the links with this command and let the switches negotiate the trunks.
switchport mode dynamic desirable on the connecting links.
iceman0813 Sun, 01/13/2008 - 18:32
what do you mean? is thay correct to use swithcport mode trunk on both 3550 and 2960 switch?
thanks again
glen.grant Sun, 01/13/2008 - 18:40
Yes you can use that also or the way I stated , which is "switchport mode dynamic desirable" instead of switchport mode trunk. Either way will work .
