%SPANTREE-7-PORTDEL_FAILNOTFOUND:
Jan 13th, 2008
Hi NetPro,
i got this logs from the core-switch : %SPANTREE-7-PORTDEL_FAILNOTFOUND: 3/16 in vlan 130 not found (telnet145) . but, VLAN 130 still in the Core-switch .
i wonder what does this means.
your reply will be highly appreciated.
thanks.
regards,
Jack
Overall Rating: 2.5 (2 ratings)
williamwalla Sun, 01/13/2008 - 20:41
I have seen this on Catos before, but it was normal and was to do with etherchannel it turns out- associated with the port coming up.
Is it causing problems
ankbhasi Mon, 01/14/2008 - 01:23
Hi Jack,
I believe port 3/16 was configured for vlan 130 which is been removed now. Can you check the config for port 3/16 and update?
The message indicates a port was deleted from a VLAN via a telnet session. telnet145 is the telnet process ID.
You are seeing these messages because you have set the spantree logging level to 7 (which will generate informational messages). Default for spantree is 5 and can be changed using "set logging level spantree 5 default".
Ankur
*Pls rate all helpfull post
ney25 Mon, 01/14/2008 - 05:04
Hi Ankur,
yes, i configured spantree logging level to 7.
but, the Vlan 130 still in the interface fa 3/16. even i show vlan i still able to see vlan 130 in the vlan database.
any idea ?
thanks.
regards,
Jack
ankbhasi Mon, 01/14/2008 - 05:50
Hi Jack,
Did you login to this box using vlan 130? Is fa3/16 is the only interface configured for this vlan? Did anyone tried enabling or disabling this port or changing this port config?
Ankur
ney25 Mon, 01/14/2008 - 05:53
Hi Ankur,
nope, that's why i wondering what happened and what went wrong.
thanks.
Jack
