shrikar.dange Mon, 01/14/2008 - 00:09
  • Bronze, 100 points or more
hi,
There are TWO main types of dual homing:
1)Two connections from the same service provider.
2)Two connections from different service provider.
Using powerfull BGP attributes you can load balance the traffic between these two connections.
for your refference:
http://www.cisco.com/en/US/tech/tk365/technologies_configuration_example09186a00800945bf.shtml
regards,
shri :)
bvsnarayana03 Mon, 01/14/2008 - 00:47
  • Silver, 250 points or more
A site having 2 links for connecting to internet either via same ISP or different ISP is said to be Multihomed site. This is done in order to achieve load-balancing & redundancy between the links.
This requires the owner of the site to have a Public AS number & a owned Public IP pool.
The site would than run BGP with the 2 ISP's to achieve the purpose. BGP uses some of its attributes to provide load-balancing & redundancy.
Link provided by Shri is a nice one. you may go thru it for further reading.
aravindhs Mon, 01/14/2008 - 05:44
Peering with the same ISP with two separate peering-points is Dual Homing.
Peering with two or more different ISPs is Multi-Homing.
Cheers
arav
