WLC 2100 Series
Dear All,
could you give me some advice to configure wlc with 2 lwapp,
i did try to used 1 lwapp ( 1242 ag ) and it's work, but when i try to connect with 2 lwapp ( 1242 & 1131 ), i can't associated with lwapp 1131 ag, i did used same configuration for both,
need youd advice and reference guide for this issue.
thanks and regards
jwadleigh Wed, 01/16/2008 - 11:53
Does the 1131 show up under the Wireless device list?
Did the AP that's not working come from Cisco with LWAPP software on it or was it upgraded from IOS? I have seen scenarios in which upgraded AP's will not associate to the controller. The way to fix this is to go to
the Security tab -> AP Policies and manually add the MAC address for that AP so that the controller will accept its self-signed certificate (SSC).
Please let me know if this helps.
Trending Topics - Security & Network
