outboud traffic session in reply are not allowed
Jan 14th, 2008
Hi all,
I have a problem with an ASA5505. Let's say I have LAN1 (10.0.0.0/24) and LAN2 (172.16.0.0/24).
Machines in the LAN1 have the ASA(10.0.0.1) as the Default Gateway and a second router(10.0.0.2) connect the LAN1 to the LAN2. On the ASA device I have, of course, a static route to the 10.0.0.2 for the LAN2 network.
When a session beging from LAN1 to LAN2 everything is fine. When a session begin from LAN2 to LAN1 the ASA blocks the traffic in response.. No access-lists are applied on the inside interface and the same-security-traffic permit intra-interface is present (also tried with and without nat-control). Does anybody know how to work out the problem?
Thanks 4 your help.
ANDREA GELATI Mon, 01/14/2008 - 05:36
I have to add just a few things.. unluckily I can't add static routes on the machines in LAN1 nor change the Default Gateway. Basically I can only change the configuration on the ASA device.
That's all.
Thanx.
