Viewing config on standby sup720
Jan 14th, 2008
I have a 6500 with two sup720's installed they are in an active and standby state.
They are both running in a hybrid mode using CatOS cat6000-sup720k8.8-3-6.bin & c6msfc3-psv-mz.122-17d.SXB9.bin on the MSFC3
My question is, is there anyway to view the CatOS config on the standby card ?
We have recently swapped the standby card out for a replacement and I would now like to view the config on it to see if the active card has synced the config over correctly ?
Thanks in advance.
Rich
owillins Tue, 01/22/2008 - 07:38
  • Silver, 250 points or more
Use show tech commands. You will get the info.
