IOS Blocking Bittorrent
yelmuch
Is there a way to stop bittorrent. I have tried using match statements in class/policy-maps with no luck.
I've moved on to using FPM but still no luck. I believe the newer torrent clients encrypted communications.
Any Ideas?
Steve
class-map type access-control match-any bittorrent
match start l2-start offset 54 size 32 regex "\x13BitTorrent\x20protocol"
match start l2-start offset 54 size 32 regex "GET\x20.*\?info_hash="
match start l2-start offset 54 size 32 regex "[a|A][z|Z][v|V][e|E][r|R]\x01"
policy-map type access-control NOP2P
class bittorrent
drop
int dialer1
service-policy type access-control input NOP2P
tstanik
Level 5
Level 5
You can create an ACL on the router to block P2P ports such as 6881 (Bittorrent). Following link may help you
http://www.cisco.com/en/US/prod/collateral/iosswrel/ps8802/ps6947/ps5207/ps6242/prod_white_paper0900aecd802efa46.html
ckarwoski
You can use NBAR within IOS to block bittorrent. Here's an example of how to do it:
http://slaptijack.com/networking/controlling-peer-to-peer-p2p-traffic-with-cisco-nbar/
