BGP Peer group
Jan 14th, 2008
we are configuring BGP Peer group manually? and the router with bgp neighbor peergroupname neighborRID will be the lead for the peer group right! somewhere i read that peer group lead is the lowest IP address router? so in that case how BGP peer group router member and lead will be elected?
bjornarsb Mon, 01/14/2008 - 08:27
I'm not sure if I understand your question, but BGP peer group RID's are not elected.
You configure BGP peer groups like this:
router bgp 100
neighbor external-peers peer-group
neighbor external-peers route-map set-metric out
neighbor external-peers filter-list 99 out
neighbor external-peers filter-list 101 in
neighbor 171.69.232.90 remote-as 200
neighbor 171.69.232.90 peer-group external-peers
neighbor 171.69.232.100 remote-as 300
neighbor 171.69.232.100 peer-group external-peers
neighbor 171.69.232.110 remote-as 400
neighbor 171.69.232.110 peer-group external-peers
neighbor 171.69.232.110 filter-list 400 in
http://www.cisco.com/en/US/docs/ios/12_0/np1/configuration/guide/1cbgp.html#wp5259
BR,
Bjornarsb
dangal.43 Mon, 01/14/2008 - 08:36
well i was having the same understanding as per your configuration but in BGP design and Implementation book I read some thing like peer group lead... peer group lead is fine router with the command neighbor peer-group command is lead but there they are talking about the router with the lowest ip address will become a peer group lead and at that point I was confused... infect i am confuse right now too...
Kevin Dorrell Mon, 01/14/2008 - 08:52
As far as I am aware, the peer group does not have any effect outside this router. It is just a convenient way of configuring a set of neighbors all in the same way, and sending updates to them all at the same time. The neighbors themselves are not aware that they are part of a peer group.
Kevin Dorrell
Luxembourg
