01-14-2008 06:48 AM - edited 03-03-2019 08:15 PM
Dear All,
I configure a static NAT on a cisco 1841.
below is the config.
interface FastEthernet0/0
ip address 213.X.X.X 255.255.255.240
ip nat outside
interface FastEthernet0/1
ip address 192.168.X.X 255.255.255.0
ip nat inside
ip nat inside source static tcp 192.168.X.Y 5101 213.X.X.Y 5101
When i telnet from my local network to 192.168.X.Y i have a result.
When i telnet from out side my network on 213.X.X.Y 5101 i have the following:
Could not open connection to the host, on port 5101: Connect failed
But when i telnet from outside to port 25 or 110 i have a result.
Any help?
01-14-2008 06:51 AM
Try this command:
ip nat inside source static tcp 192.168.X.Y 5101 213.X.X.Y 5101 extendable
HTH,
__
Edison.
01-14-2008 07:05 AM
Did you allowed the 5101 port from outside using access-list.
Post your access-list applied on the outside interface.
01-14-2008 08:31 AM
Below is the ACL
ip nat outside
ip access-group 101 in
ip nat inside
access-list 101 permit tcp any host 213.X.X.Y eq 5101
Thks
