1841 with VoIP
Answered Question
1841 allows voip in pass-through mode.
What software version do you i need to implement this?
Correct Answer by Brandon Buffin about 9 years 1 month ago
According to Feature Navigator, you will need 12.3(8)YG or later with one of the following feature sets:
Advanced Enterprise Services
Advanced IP Services
Enterprise Services
SP Services
Hope this helps. If so, please rate the post.
Brandon
Overall Rating: 5 (2 ratings)
Correct Answer
Brandon Buffin Mon, 01/14/2008 - 08:59
Enterprise Services
SP Services
Brandon
Brandon Buffin Mon, 01/14/2008 - 09:38
By following these steps:
1. Go to Feature Navigator (www.cisco.com/go/fn)
2. Choose Search by Feature
3. Search for VoIP
4. Choose the feature Voice Over IP (VoIP) and click Add
5. Click Continue
6. For Platform, choose 1841
You will see that the dropdowns for Release and Feature Set only contain the entries listed in my previous post.
Brandon
Paolo Bevilacqua Mon, 01/14/2008 - 10:25
Wait a minute Brandon :)
One has to define first what is meant "voip in pass-through mode".
If is what it think, that is routing and applying QoS/marking/NAT or whatever to voice packets, I think any image would do that.
