Configuring Net-SNMP
Jan 14th, 2008
Is there any to configure Net-SNMP to print the IP of the device in each returned line of a query?
For example, the following is the current default return when I query the ifAlias of a switch:
IF-MIB::ifAlias.12013 = STRING: 228A
IF-MIB::ifAlias.12014 = STRING: 228B
IF-MIB::ifAlias.12015 = STRING: 035B
IF-MIB::ifAlias.12016 = STRING: 053A
IF-MIB::ifAlias.12017 = STRING: 029A
IF-MIB::ifAlias.12018 = STRING: 125A
IF-MIB::ifAlias.12019 = STRING: 051A
IF-MIB::ifAlias.12020 = STRING: 203A
IF-MIB::ifAlias.12021 = STRING: 253B
IF-MIB::ifAlias.12022 = STRING: 212A
IF-MIB::ifAlias.12023 = STRING: 170B
IF-MIB::ifAlias.12024 = STRING: 253A
IF-MIB::ifAlias.12025 = STRING: 187A
IF-MIB::ifAlias.12026 = STRING: 064A
IF-MIB::ifAlias.12027 = STRING: 066A
IF-MIB::ifAlias.12028 = STRING: 252A
IF-MIB::ifAlias.12029 = STRING: 187B
IF-MIB::ifAlias.12030 = STRING: 191A
However, I was wondering if the output of this query can be configured to include the management IP address of the switch in each and every line of the above output.
Overall Rating: 3.5 (2 ratings)
Joe Clarke Mon, 01/14/2008 - 10:12
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
There isn't an output option for net-snmp that will do this. You will need to buffer the output in a script or program then print out the lines with the added content.
yuchenglai Mon, 01/14/2008 - 10:15
That is what I thought. I have figured out within DOS out to buffer the output to a notepad text file. Now the next step will be to figure out how to write a script to add the content.
